Muse
I have some data on the 3TB WD ELEMENTS HD that I'm sending to WD tomorrow after having received a WD 3TB My Book replacement (advanced replacement). Some of that data on the HD I'm sending back to them is a security concern. Should I first use WD Lifeguard Diagnostics to over-write the drive with zeros? 😕
I copied over the data from the HD that's going bad to the replacement drive and most of it copied but for ~45 objects (files or directories, not sure) I got messages that the file names were too long, skip or cancel. What's that about, seems crazy. I had to skip or cancel those so I couldn't get all the data. Around 45GB copied, around 1GB did not copy. Probably I have that data elsewhere, but ...
