How can i cut a paving slab with basic tools?
Atheus
7,313
I need to cut a few concrete(?) paving slabs as a base for a shed. I reckon the best way would be to score it with a grinder, then tap it with a mallet, and it should break on the line.. but I have no angle grinder, nor a grinding blade for the circular saw... I do have hammers, chisels, etc and some basic power tools.
Any ideas?
FoBoT
63,084
15
fobot.com
does it need to be a perfect straight break?
if not and it just needs to be ballpark, then just use the chisel (widest one you have) and hammer
35,132
I can't think of any way to do this with what you have that wouldn't cost more in terms of damage to the tools than it would cost to buy a grinding blade.
Atheus
7,313
No it doesn't have to be perfect. I have a masonry chisel and a club hammer, that was the first thing I thought of, but I really want to score it before I start bashing away.
I've got an old chipped chisel here I was thinking of using to score it... I don't really care about the blade, and besides I can always put another edge on it with the dremel.
Will I be able to get a deep enough score by scraping it with a chisel? We're about to find out I suppose.
Atheus
7,313
Originally posted by: DivideBYZero
Just use your face.
First you must fill your head with knowledge, only _then_ can you break concrete blocks with it.
csiro
1,261
You could put a couple of holes using a power drill along the break line and then snap the slab by connecting the holes using a chisel.
blert
926
If you have a basic power saw, buy a masonry blade. They cost about $10-$15 and will do the job quickly and cleanly. I have a very cheap craftsman that i keep around just for that purpose. Just be sure to wear earplugs and eye protection when you are cutting.
