how can i change my irq settings, video and network is using same irq setting.
you can make these changes in your bios settings,... but if your not familiar with messing with irqs and such, you can cause quite a mess with the whole irq config,... if you have open pci slots, i suggest you just change the position of your network card... = ), and the auto-irq will reassign different irq's... if this doesn't work, consult your motherboards manual, some manufacturers supply info on the actual irq's shared by specific pci slots... hope this helps!
