How are tires removed from rims?
Shawn
32,236
53
I figure I can't do it myself, so I got a quote at a local shop and they said it'd be $30 for all 4. Is that reasonable? Seems a little high.
spidey07
65,469
With a tire mounting machine.
Basically rotates tool around the wheel to take each bead of the tire off. Same tool used to put the tire on the wheel. Normally air driven and the tires is mounted to the machine, while an arm rotates around the wheel.
takes just about a minute per wheel.
Jun 4, 2005
19,723
You must use a nice machine.
The ones at the shop where I used to work, you'd have to use like, a pry-bar to get the tire over the lip of the machine. It was a pain in the ass.
Goosemaster
48,775
that's how I've always done it....but I've never had good rims or lowprofile tires....
Shawn
32,236
53
Originally posted by: BoomerD
If the $30. is for mount AND balance, that's a good price.
Well I just want to dispose of the tires. I sold the wheels to someone.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
So, you only need the tires removed, then you're disposing of the tires?
Sledgehammer to break the bead, followed by a couple minutes with a reciprocating saw/hack saw.
tbike06
1,092
:thumbsup:
Apex
6,511
www.gotapex.com
In before someone whines about the use of the word rims instead of wheels.
$30 for 4 is not too bad. Considering their labor time, invoicing, dead time, and value of machines, I doubt they're making much money.
BoomerD
66,634
15,024
Are the tires worth keeping and re-using or selling? If not, let the buyer of the wheels deal with them. If they are, then $7.50 isn't that bad for dismount.
DrPizza
Mar 5, 2001
49,601
167
111
$30 isn't a lot to spend for those unusual 1-time events. However, compared to most places near me, that $7.50 per tire is a complete rip-off. Assuming all 4 are off the car, it's no more than a 10 minute job. That's $180 per hour for labor...
Generally, for $7.50, you can get old tires removed, new tires put on, and the tires balanced as well as put on the vehicle. This is the easiest step, for the same price.
nakedfrog
63,383
19,751
I wanna be your sledgehammer.
pontifex
43,804
46
thats how my tire shop does it too.
