How are these temps?
AtomicDude512
CPU: 44/47c
Rig: 33/25c
Dual-Fan TruePower PSU
2 Thermally Controlled Case fans
Is this enough or do you think I need more cooling before summer comes along?
Athlon XP 1700 Palomino @ stock speeds
512MB PC2700 Kingston DDR
MSI GeForce4 Ti 4200 VTD
Maxtor DiamondMax8
16x10x40 LG CDRW
Knowing what your ambient/room temps are will be the diffence...20-30deg c is going to make quite a difference with heatbuild up in your case, OR....run fresh air directly to your cpu fan...via a venthose..there is a good write up in the forums.
If you are worried about heat being an issue....I would suggest to ANYONE if heat is an issue...switch to water cooling.
Tuff
