To anyone who has first-hand experience of this heatsink...
I recently bought a Scythe Ninja and although I got it fitted quite easily without a fan, things got nasty when I tried to fit a 120mm fan. At first I thought it was specific to my motherboard, but I have since looked at a lot of different 939 motherboards and I'll be damned if I can figure out how I would fit it on any of them.
With the most common configuration (example), the cpu socket is between the back plate and the memory slots. Ideally I would want the fan on the memory slots side of the CPU, blowing through the Ninja and out the back of the case. However, placement of the fan is obstructed by dimms in any of the slots. With a certain amount of trouble I can mount the fan higher, but then I miss supplying airflow to the base of the Ninja where there are "normal" vertical fins and temps go up.
I could go on and critique every possible position for the Ninja with this motherboard layout, as well as others, but I won't bore you. Suffice to say I don't understand how I am expected to use a fan with this thing.
