So, I have a pretty complicated A/V entertainment setup I think. I have a hodgepodge of old and new technologies. Here is what I have:
-A Doblby Digital compatible pioneer receiver with regular composite video inputs/outputs only(no component or s-video).
-A Tivo
-A replayTV
-A regular cable box
-A HDTV cable box
-A HDTV RCA widescreen TV.
Right now, I have the receiver hooked up to get sound only, I am not passing any video through it.
The regular cable box is hooked up to the Tivo
The tivo is hooked up to the TV via s-video
The HDTV cable box is hooked up to the ReplayTV via s-video and the RCA TV video DVI.
The ReplayTV is hooked up to the TV via s-video
The audio for the Tivo, Replay, and HDTV cable box are hooked up to the receiver and the RCA HDTV.
SO, if I wanna use the Tivo, I have to switch to "Vid2" on the TV using the input button on the TV, and then I have to pick up the tivo remote and use that.
If I wanna use the replay I have to again use the TV remote for the input button, cycle through the inputs to Vid1, then use the replayTV remote to control things.
If I wanna use the HDTV cable box directly, I have to cycle to the DVI input, and so on.
If I want to use the receiver for sound, I have to switch to the correct input via the remote on the receiver.
Overall it's a little confusing at times, and my fiancee is getting annoying with me for making everything so complicated. I guess a newer receiver component switching could solve most of my problems, but I don't want to buy one of those yet.
Can I get a remote control that will allow me to hit a single button, which will switch the TV to the right input, change the receiver to the right input, and then the functions on the remote control will control the Tivo for instance? Are remotes "smart" enough to remember which input they are on?
-A Tivo
-A replayTV
-A HDTV cable box
