How accurate is NVIDIA System Monitor Temps?
BroadbandGamer
976
NVIDIA System Monitor is showing my temps as 49, 46, 40, & 40.
ABIT Guru and the BIOS are showing my CPU running at 60C. For some reason ABIT Guru and the BIOS don't show the temps for each core.
So which one is correct? How can I find out for sure what my core temps are?
This really isn't video related. I'm punting this over to motherboards, they should be able to give better answers.
-ViRGE
BroadbandGamer
976
I'm using CoreTemp and it's showing the same temps as NVIDIA System Monitor.
So are the temps in the BIOS wrong or is CoreTemp wrong? The BIOS temp seems way too high.
Donts00tmesanta
587
39
speed fan crashed my systems
core temp is awesome bios temp is hella high while coretemp temp is like 30 degrees less
