Tarvaln
I moved into a new place that was built in the 60's. I set up my UPS and PC everything powered on fine but I noticed my volts on the UPS were lower than at my previous place.
Old place 121 volts no matter what.
New place 119-120 PC off, 116-118 PC on
I was playing Rise of the Tomb Raider and then after an hour my UPS started to beep like I lost power. But none of the lights went off. Then my PC shut down.
I thought maybe the outlet was bad so, I replaced it and the other in the living room. I noticed on the one connect to my PC there are only 2 wires. One black, one white. On the other outlet there were four wires, 2 black and 2 white.
Would it make a difference to plug the UPS and PC into the other outlet?
Also, is there a way to get the volts back up to 121 if that even matters?
Thanks for reading all of this!
