Hot XFX 6970
leper84
I'm at wits end here. Here is what I have-
960T/212+ (stock clocked & locked), sabertooth 990fx, gskill 1333 4x4gb, corsair gs600 +12v 48A
I (stupidly) traded my perfectly working twin frozr 560ti + cash for a reference xfx 6970. I was using a coolermaster centurion 534 and temps were stupid high- 60c idle, 95c+ load (metro 2033 bench). So I figure I need more air and go get a HAF 922.
Temps were great- 30-40c idle, 80c-ish load. Then I decided to try and use the asus autoclock crap in uefi and everything crashes getting into windows. System restore won't work, so I redo everything.
Now the g****mn thing is back to idling at 60c and 95c+ at load. If I force 100% fan it refuses to go under 50c.
The power supply has a single 12v rail and using OCCT powersupply test and a multimeter the thing refused to back down from 12.4 vdc; so I think that is good.
OS is Win 7 64bit updated all the way. Drivers are directly from AMD.
Is it possible the guy before me just overclocked the living d**k out of this card and its leaky and about to die? Basically, could this be a software/bios/whatever issue, or should I just find an excuse for 7950?
Yeah, sounds like the card just got wrecked by the last owner. Did you get a double lifetime warranty transferred?
Also, I would go in and replace the thermal paste.
Previous owner never registered the card so I'm s.o.l. on the warranty.
Edit: Derp, forgot two screws.
Also turns out this is one of the infamous xfx revision cards with no bios switch and cheaper parts... so not surprising its crapping out....
Yeah, then going in and replacing the thermal paste with something non-conductive while re-positioning the heatsink is your best option.
Shouldn't be too difficult...check YouTube and see if anyone posted any tutorials/dis-assemblies.
Yeah last time I took a cooler off was a gts 240.... but I figured it out after awhile.
Second try was able to get idle temps down to 40c and load around 80ish, forcing a fan profile with afterburner I'm able to keep it around 70c. Tim was a good idea, had some as5 laying around doing nothing anyways.
Silver lining I've got it overclocked at 950/1450 @ stock voltage, did 15 runs of metro 2033 bench with no artifacts, crash or anything; gonna do some occt or furmark to make sure
Is there any way/program to overclock it higher? CCC and afterburner stop where I'm at.
