HOT! Toner for samsung 1710 for $63
GoingUp
16,720
Office Depot has a $20 off $75 coupon right now.... Its a real copious coupon
Buy the toner for $78.34 - 20 + tax = $63.xx with free delivery or in store pickup.
I know a lot of you have this printer, and toner normally runs $90.
Enjoy! :D
tm
4
Nice price. Even better on a new cartridge.
I just picked up one of these printers today and I've been looking around for cheap toner. That beats everything I've found so far, even on non-OEM... Lowest I've found so far is $58.99 (+7.99 s/h) on a compatible one from NexImaging. I ran across a toner refill kit for about $33 too, but I don't know if they're worth it or not.
Thanks for the deal.
hallf
513
Originally posted by: breweyez
heres a link to a toner refill kit
http://www.tonerrefillkits.com/refill_products094.htm
im not sure if im gonna get a refill...my prints havent been coming out as well as when i got it...anyone have problems printing envelopes??? they come out really light....but the test page looks the same as when i got it
I've noticed that with envelopes, so I tried turning the toner saver on and off and it didn't make any difference. Are you using Word's envelope tool to enter the addresses? I am...and I think it's some weird thing Word is doing...it's almost like it's not printing characters, but is printing a bitmap of the address and it looks like it's grayscale or something.
Epinephrine
My prints were getting lighter too.....I did shake the toner slightly and that seemed to fix the problem.
Does anybody know/remember if the toner that came with the printer was a starter one??
How many prints does this provide??
Murse
236
I also get light printing on envelopes using an older Samsung 4600 with MS Word. I might try StarOffice and see if there is the same problem. If so, it could be a driver issue.
GoingUp
16,720
It is a starter one good for 1000 prints..... if you hold down the toner save button for about 3 seconds and then release, you should get a printer status page that will tell you how many pages youve printed
albrandwood
163
kewl ... I thought mine was running out of toner ... didnt thinnk I'd done 1000 prints ... I havent ... only 240 ... so I took the toner out, and shook it ... and surprise ... black is black :) ... I wonder if the toner has problems if it's not used a lot ...
@shley
VNamee
45
I just bought toner from ebay. Like the 18 dollar one for 2 65 g bottles someone mentioned above. Works great. Its really easy to change to. Just pop the stopper off on the right side of the tube part, and pour away. It was a bit messy the first time I did it, but now I know to give it some air flow. I'd suggest perhaps doing it in the shower or something if you're afraid of toner all over the place. But for an 18 dollar replacement, it works great.
gypsyman
674
9
Tonight is the last day you can get this. Just ordered my online shipped $63 plus tax.
weepul
5,134
www.hd-trailers.net
Originally posted by: Crapkilla
I wouldn't worry about it, it's $62.98 every day at Buy.com and free shipping.
nice. but if u order from OD, dont forget to sign up for the OD Advantage for upto 10% back. that's like ~$6 back
//krunk (^_^x)
Mail5398
400
I just put a new toner cartridge in and the printer still does not print that great on envelopes. Perfect on a piece of paper but not an envelope. Must be some kind of defect. Oh well, can't complain. Paid $100 for a laser printer. What do I expect.
andykong
Can someone share with me how you refill the toner for this printer? I can't find the hole plug from cartridge. It seems fixed on the tube part. There's no place to pop anything out.
Thanks in advance!
magomago
10,973
14
Got mine today...WOW the ink quality shot up- now i'm wondeing if my "starter pack" ever really was rated for 1000pages (yes i did shake it)...
either way, 300dpi + toner save on the new one looks better than 600dpi w/o toner save on the old one
i'm satisifed ^^
Hodaddy
87
Thanks in advance!
Check my post in this thread. Original toner fill is very weak!!
Archive:)
rexfalk
171
There is a firmware update from Samsung that is supposed to help the light envelope printing. My toner ran low after about 600 pages and wouldn't print an envelope at all until I refilled it. Some have commented that the update help though.
Rex
hallf
513
Rex
Can you point to a URL for the firmware update? I've looked all over the Samsung site and all I see are USB and printer driver updates, but no firmware update.
UPDATE: I emailed Samsung about the light envelope problem, they emailed me the firmware update as a response. I'm not home now to try it out, but will try to report back later.
KKCC
388
This link shows in detail hoow to refill
Have Fun
And a quick EBAy search shows this, ( This is for example only, I'm not saying whether this seller is good or bad. If you know another that you have dealt with please post)
Enjoy
