I'm trying to use a set of internal SATA drives for backups on Windows Server 2003 SP2. The SATA drives are in hot swap trays that can be inserted into a mobile rack. The rack connects to the motherboard using a standard SATA data cable.
The drives in the trays seem to work fine, but I'm having problems getting them to be hot swappable. When I took out one of the trays and inserted another to format the hard drive in it, the system reset.
What do I need to do to make this work? I was assuming SATA II drives and motherboard chipsets supported hot swapping. The board has an Intel 5000V (Blackford-VS) chipset and Enterprise South Bridge 2. The mobile rack is a Kingwin KF-811, and the SATA II drives are Western Digital 160GB WD1600JS.
