HOT! superquiet Pabst 80mm fans $4 (regular retail $20)
tsee
382
Please update the posting to reflect the following condition:
"1. Our minimum merchandise order is $25.00 excluding shipping. Orders placed which are under that amount will be cancelled unless you indicate in the comments field that you are will to pay a handling fee to meet the $25.00 minimum."
'Nuff said.
wyvrn
10,074
Oooh cool. Do they have 60mm fans?
edit: nope they sure don't. Nice deal if you need 6 or more of these.
Lizardman
1,990
These fans are 24volt fans not 12volt.... Wrong link cheack here for there 12vdc fans( the kind you put in your pc). 12vdc
phreakyzen
423
Are you sure these are that quiet? I know the Pabst 8412NGL is super quiet but can not find the ratings on this one.
StevoDaDevo
113
I dont know about Pabst being quiet... When my buddies get a bunch of Pabst in them, they are loud as HELL.
Lizardman
1,990
This place has lots of other good fans. They have some cheap 120 mm deltas for $4 and the shipping is only like $6 for 8 fans which is a reasonable price.
Brix13
137
I'm going to try to stop by there tommorrow and check it out since I'm off. I need a couple for my two cases
lsman
3,869
www.flickr.com
look at the closeout section:
Item ES1195
Computer Switching Power Supply. +5V 15A, +12V 6A, -5V 0.3A. -12V 0.3A.
Has 3 Hard Drive connectors, 1 Floppy connector, 1 12-pin motherboard connector.
On/Off switch on back.
750 In Stock.
Unit Price $5.00 each. Now only $2.00 each
some LCD for $0.25, 0.20, 0.4 etc.
In computer:
Item GDM5021PT
Silicon Graphics (Sony) 21" monitor (19.8" viewable)
1600 X 1200 max resolution. Deflection Frequency Horizontal: 30 to 107kHz Vertical 48 to 160Hz. AC Input: 100 to 240VAC Power: 160W Maximum.
Has both HD15 and 5 BNC connector input.
46 In Stock. 30-Day Replacement Warranty
SPECIFICATIONS
Unit Price $300.00 each.
Jugernot
6,889
Anyone ever think, that maybe the reason they are superquiet is because they would be running a 24v unit at 12v? You can quiet any fan by running it under spec... the only problem is that performance is cut also.
Jugs
IgoByte
4,765
Guys, this monitor is a hot deal. This is the same Sony tube/monitor that Dell uses and sells for around $800. IMO, those Dell monitors are the best they've had.
Here are some important things about it:
1. It's not a fixed frequency monitor, which is good.
2. It has dual inputs and according to the guy I just spoke to (very nice BTW), it has the ability to switch between two different computers (like the high-end Sony branded monitors and my own FW900).
3. It's near flat-screen. I'm not sure if it's completely flat, but it's a good screen nonetheless.
4. Shipping is around $40, which makes the total around $340.
I think I'm going to get me one of those.
IgoByte
4,765
Well, it's performance is cut alright. It throws out only ~19 CFoAM. However, it is a LOT more silent than any other 8cm fan I've seen. This is great for a PSU or just to cool HDDs.
anandfan
871
I think this heatsink might be good for cooling chipsets:
Item ES2277 Heatsink
51.7mm W x 54.7mm D x 25mm H
114 In Stock.
Unit Price $1.50 each
(a little large, but a hacksaw will fix that!)
Heatsinks (several pages)
Flatpicker
301
<< Note: Please remember that if it isn't on our web pages we don't have it. >>
lol
nice find
chizow
9,537
<< Guys, this monitor is a hot deal. This is the same Sony tube/monitor that Dell uses and sells for around $800. IMO, those Dell monitors are the best they've had.
Igobyte , when you talked to the guy did he tell you if they were new, used, or refurbed?
Also, after looking at all the resolutions and refresh rates, I'm not sure what to make of the graphics mode settings. If this thing can run games and my desktop at 1280 with 85hz refresh, I may have to hop on this as well.
Chiz
matrixvision
119
If you are in need of cheap fans, there is a thread on panaflo L1A's for $2.50 that kick @$$ and are super quiet to boot
lsman
3,869
www.flickr.com
<< If you are in need of cheap fans, there is a thread on panaflo L1A's for $2.50 that kick @$$ and are super quiet to boot >>
But if u need 92MM, or 120MM fan. Can't beat this price of $4, $5.
I think Item ES2382,
Delta Fan 12V 0.08A Model ASB0912L 92mm X25mm $4.00 each is very good , 0.84W, 2100rpm, 37cfm, 25dBA.
nice quiet fan!
Phunktion
2,502
The Pabst you linked to are (24 Volt) Fans they will not work with regular computers as someone mentioned above.. I checked the 12Volt section and there are no Pabst's.. too bad I really wanted at least 6 of em :(
Here is the Cheap Panaflo L1A Thread
WageSlave
Banned
Sep 22, 2000
1,323
I got the panaflo l1a ... it is loud.. I am very dissapointed.. it doesnt sound any quieter than my cheap a$$ 80mm fans that came with my case
Squisher
21,204
66
Well, I guess you could get 24 volts in your computer case by tapping into your mobo connector and using -12v and +12v. Although I have no idea what this would do for your stability.
wluk
Guest
Feb 2, 2001
1,676
<< I got the panaflo l1a ... it is loud.. I am very dissapointed.. it doesnt sound any quieter than my cheap a$$ 80mm fans that came with my case >>
totally agree
Cybordolphin
2,813
The Delta 120mm fan #WFB1212LE is a winner. UP to 84 CFM and only 34DBA. Very good for a 120.
AND the voltage can be played with to lower the #'s (noise) a tad.
I really like throwing these into the front of my cases (after moding). I find it actually much less noisy than installing (3) or so smaller fans.
This Delta looks like a nice fan. I usually use the Panaflow 120mm fans.. but will give these a try.
Thanks for the post.
NeuralChaos
wth? loud? My 60 mm sanyo denki fan on my pal6065 heatsink makes more noise then all 4 of my panflo l1a's combined!
