Most of the useful
articles and
user opinions I've read on this monitor state Sony is inconsistent with the quality of these monitors. The problems tend to be limited to geometric distortion, brightness, and fuzzy image quality (although I believe some of this is due to video card usage).
A 0.24mm dot pitch on an aperture grille isn't directly comparable to a shadow mask. For example 0.22mm stripe pitch on an aperture grille will have 0.22mm horizontal while only a 0.44mm vertical. A 0.24mm pitch would probably be equivalent to a 0.28mm shadow mask, resolution wise. Meaning, at high resolutions, text won?t look to great, but games should look fine. Here's an old ZDNet
article on pitch that should make all of this clear.
The monitor is
"Virtually-flat", as stated by Sony' website. This is an allusion to the slight cylindrical curvature of the monitor--vertically flat, but not horizontally flat. This shouldn?t be noticeable, unless you use your monitor for a mirror.
I hope this helps.
