HOT Power Supply Deals At Performance PCS!!!!
mriccucci
Coolmax
Coolmax Green 1000 Watt SLI/Crossfire Certified Power Supply - Sleeved $379.95 $279.95 After Rebate
Coolmax Green 850 Watt SLI/Crossfire Certified Power Supply - Sleeved $259.95 $184.95 After Rebate
Coolmax Green 750 Watt SLI/Crossfire Certified Power Supply - Sleeved $169.95 $119.95 After Rebate
Coolmax Green 700 Watt Modular Power Supply with 120mm Fan - Sleeved $149.95 114.95 After Rebate
Ultra
Ultra X-Connect 500W ATX PS w/2 80mm Fans - Black w/UV Green $59.95 $19.95 After Rebate
Ultra X-Connect 500 Watt ATX Power Supply - Titanium $59.95 $19.95 After Rebate
I Just Grabbed one of thoose 850 watt coolmax's and one of the titanium powersupplies There awsome. The 850 is rocksolid in my system and im using the 500 for a benchtop PS i couldn't beat getting a 100 ps for 20 bucks!!! Performance-PCS ROCKS!!!!!!!!
ImDonly1
2,357
Why is Coolmax on the list to avoid power supplys over here... Here
Same goes for the Ultra.
With one post it seems as if you work for performance PCS. These deals aren't very hot for performance PCs. Maybe for a budget build.
araczynski
1,252
that list is a joke if you ask me, apparently they want everyone to believe that all quality PSU's must cost at least $100 before they're even capable/worthy of being 'performance'.
please, i've been overclocking since day 1 and have been using ONLY power supplies that are under $100, and have YET to have so much as a single issue with anything, and i've been using at least 3 hard drives and 2 opticals, overlocked cpu's, overclocked gpu's, fans and lights galore, you name it.
this is the same as saying you need SLI-7900gtx to play half life 2 smoothly.
Indyboy2
317
Not bad i have bought alot of stuff from them including a xscale 750 watt psu they are great to deal with
ImDonly1
2,357
I agree. I would not buy a PSU over $60. I am not sure about the quality of these PSU's you might want to read seperate reviews. That list seems a bit general, but its a good rule of thumb. I have read many reviews at online merchants on the Ultra X-connect's breaking very soon after use.
Kavikgold
169
If you guys are clueless about powersupplys, i'd highly suggest you head over
here
and make yourself knowledgeable as to WHY some are good and WHY some are bad. Or, you can just skip to the end for the list of recommended powersupplys.
mindless1
8,427
1,595
Welcome to AT, mriccucci
You have a strong affinity for performance-pcs.com
Why does it always look suspicious when one's first post starts out like this? Hmmmm.
I'm afraid we're a little too picky to pay post-$100 for a coolmax though, and the ultras, while possibly worth $20 for an old system, can be had as regularly recurring deals at Radio Shack, IIRC.
$280 after rebate is just obscene though, I'd sooner buy insurance and hire a rent-a-kid to stand over the system with a fire extinguisher. All kidding aside, 1000W should never be pulled from a PS2 (even extended length) form factor unit. That's full sized server territory for a reason, they don't just make them larger on a whim.
mike2fix
6,715
"mriccucci" may have some affiliation with Perf PC, but it is owned by Hank Baron, also known as "Rainguy" who was a very active trader here years ago.
filibusterman
1,319
i guess i should consider myself lucky that my 400watt ultra x-connect has been fine for about a year now?
