- Oct 3, 2006
- 1,971
- 0
- 0
I'm accustomed to hot plugging USB devices, but I found an article on the WDC website, that said that if the SATA power connector was used, vs the molex, that it was hot pluggable. Is this really safe?
Safe in what manner? Safe electrically or physically, or safe for the data on the hard drive.
Fullmetal Chocobo,
Considering the voltage, I'm not concerned about physical harm, assuming that you mean personal bodily harm. I'm not sure what you mean by electrically. My question regarded harm to the data on the drive, as well as physical harm to the drive, as well as other components of the system.
My system only has a 2 drive raid capacity, but I have a third, which I intend to do some diagnostics with. It would be alot easier if I did not need to shutdown everytime to switch drives around. This would mean removing and adding drives to the array. To this point, the new drive isn't being recognized by the bios, causing the machine not to boot at all.
My SATAs are in a raid 1 array. I know that if a drive is disconnected prior to power up, it will offer to rebuild the array. But, I have no idea of what would happen if a new drive was exchanged after powerup. Can the bios make changes while powered up?
