Hot PC in a Silverstone SG05 case
I want an HTPC and part-time business computer, so I've decided to build one using a Haswell CPU, water cooling, and a very small case no more than 8" high.
The Silverstone SG05 is 7" high, 8" wide and 11" long so it fits the space I have under the TV. I got a bare case in the off-white colour.
i5-4670K in an ASUS Z87I-PRO mobo
And a Zalman LQ315 closed loop water cooler with the original 120mm fan.
Mounted with Noctua NT-H1 paste (based on IDC's research in his 3770k delid thread).
My main PC donated half its RAM: 2 x 4Gb G.Skill ARES 1866.
At this point I decided to increase the incoming airflow.
This meant opening up the front panel of the frame. More work for the jigsaw on a very awkward and flimsy piece of metal.
And I added a few more holes at the back as well.
research identified the Thermalright TY-141 PWM fan as a good 140mm performer with 120mm mounting holes.
I needed to conceal the metal colour and Warhammer Plague Brown paint was a good match.
The plastic front finishing panel also need work to increase the intake size.
Reassembled. The disk drive mount now fits flush to the front. The PSU is a Silverstone 450 SFX unit. Forget fancy cable routing, everything is just squeezed in.
Graphics card side. The radiator restricts the length of card but a Zotac GTX760 AMP! fits ok and is more than fast enough for my purposes.
Awkward job getting it in there though, and wired up.
That's a tight fit!
Lid on.
And I found a finger guard grille on eBay. Not the best finish but it works.
I've got plans to paint the case but first I really want to start it up. But nearly midnight her now so that's for tomorrow..
Looks well and truly packed in there. Maybe a modular PSU would be a better choice?
Your jigsaw work is quite good.
I installed Windows 7 and MS Office 365. For initial test runs, to get the feel of the CPU, motherboard,overclocking options and temps, I used an Excel benchmark that's very single threaded and imposes a low load on the CPU and is typical of the sort of work I do on my PC.
http://dl.dropbox.com/u/87381454/EXCEL-SPEEDTEST-v1-(John-Tauwhare).xlsb
There was a cold gale blowing outside so by opening the window I got an ambient of about 16C. I kept the fans at max. At 4.9GHz the core temps were around 55C.
I got two runs at 4.9GHz then a BSOD. Not willing to go above 1.45V even at low load but I'm happy with these results as they suggest I could set 4.5GHz and 1.2V for day to day use (temps around 40C).
