hot or not: tv -> usb2 at 27$ with remote
nivw
117
question is how good is the quality?
Can it do linux?
ripped from techbargains
Shipping: $4.95 - SKU: TV USB20
$3 Coupon Code: techbargains259
TV Tuner/Video Capture Box with Remote Control USB2.0 Retail
Specifications:
TV Tuner: Yes
FM Tuner: No
Remote Control: Yes
Interface: USB 2.0
Video Display: NTSC 30fps 720 x 480, PAL 25fps 720 x 576
Video Format: Mpeg4/2/1
Ports In:
Audio Input
Coaxial TV Antenna or Cable Input
S-VHS Input
Composite Input
Operating Systems Supported: Windows 2000/XP
System Requirements CPU: Pentium III 800 MHz or above
Memory: 64 MB or above
VGA Card with at least 8MB memory
An USB 2.0 Port
CD-ROM drive
Features:
New and high performance USB2.0 IC, no external power required
Support NS-High Speed, data transfer rate reached 480M bps
TV Record at resolution NTSC 704x480
S-VHS and Composite input. For high resolution Video Capture. NTSC 704x480
Video Adjustable Saturation/Contrast/Hue/Brightness.
Capture and Record as Standard Format (ex. AVI, MPEG1, MPEG4 etc.)
Bandwidth Adaptive Automatically Control.
Audio Capture & A/V Sync. Function.
Full channel (supplementary channel contained) scanning, up to 125 TV channels receivable
Support TV, Video, DVD/VCD displaying and watching, music listening, picture browsing
Support multi-national languages
Support audio/video USB mongline transfer
Time-shifting
Scheduled recording
Remote control
Package Contents:
USB 2.0 TV Tuner / Video Capture
Remote control
Software CD
Batteries
munchydoan
45
I just got mine and played with it over the weekend.
The quality is precent darn decent. I plugged my antenna in and the reception was as good as with my other TVs in the house.
Recording quality at the highest setting was impressive. I "taped" the FOX sunday night shows and then played them back later on my laptop using Windows Media Player and I gotta say that it looked better through that than through the WinDVR software it comes with.
For $31 total, it was a steal.
KenSr
1,441
:) I am thinking about getting this.
:confused: I sure wish there was more input about it.
isayx3
34
Will this work with Windows Media Edition? I want to get an HD Tuner but from what i read you need an analog tuner in your system first. I'm thinking this would be a cheap option.
Baldy18
5,038
Originally posted by: Bassist695
I'm sorry, I'm not buying from any site that spells freight like this:
Fright:
$4.95
You could order from the other site and get one that is "USB 12.0 and USB 1.1 compliant".:)
ECartman
756
any outputs? It doesnt look like it. Can someone confirm?
I'm looking for something to play movies from my laptop DVD drive onto a television.
Slickone
6,120
Would this be a good choice for converting VHS tapes to DVD? I want to keep the best quality I can obviously.
BigEdMuustaffa
1,361
I've done extensive research on converting VHS tapes to DVD and the best solution I came up with is an S-VHS player connected to my digital camcorder via S-video and audio cables, passed thru to my pc, via firewire and audio cables.
mikeford
5,671
160
For quality on a VHS transfer Big is right, item one is a high quality S-Vhs player, then many good choices for converting the resulting video.
RE the HD OTA, do some more research as its a moving target, but last I checked many like the Fusion cards, USB seems to have some issues.
BTW this card isn't HD is it, just old style SD video.
mikeford
5,671
160
Also it doesn't appear to do any encoding in hardware, just tunes, converts, and passes the raw data to the PC and uses the cpu to encode.
