hot? OD NiMH Battery Upgrade Kit for T6000 series
tojunk
42
there are some NiMH Battery upgrade Kit 56319 on OD clearance table. the sale price is $19. but if you bring it to the manager and tell him that you found them on the clearance table, he or she will cut the price to $8.88. i took some from regular shelves, and did the same. at yahoo shopping sites, this thing sells from$35-$$45. the price will be higher at regular retail shops. the kit is compatible to all Talkabout two-way radios 6000 series. good luck.
