***Hot*** NEC ND-3500A 16X Double Layer DVD±RW Drive + 5-PK 4X DVD-R for $62.99 Shipped!
PicPop
Hot! Turkey Day Blow Out! Newegg has the NEC ND-3500A 16X Double Layer DVD±RW Drive (black) for $62.99 + free shipping!
Don't forget to select the Free 5-Pack 4x DVD-R Discs (see Special Combo on the product page).
Link
This is a nice drive! I just got one from them last week for $68.99, I guess I should have held out a little longer!
My goodness, can this deal get any more tempting? Unfortunantely I do not have the cash right now. I am oficially jealous of the rest of you.
Great deal !
ChunkyBarf
P.S. Happy Thanksgiving
Originally posted by: TygGer
Cant remember, is this one considered the best dvd burner for the money at the moment?
I use a 2500A for work, and it is sweet! This should be great also. Not sure if it's the best though.
ok.......stupid question, but i need to know... i was planning on getting two of these for my new rig (going to order next month after I find out about nforce 4) but then this opportunity came up...pretty cheap, can save bout $15. Anyway, the stupid question...if I order EOM what will I need to get. Obviously it doesn't come with the CD that you see in the pic and I will need some wires to run to board...
need some help here...
thanks...
HAPPY THANKSGIVING!!!!!!
thanks...
an ide cable and a free molex power plug
ide cable
if you don't have a free molex power plug, here's a splitter
usually a computer that isn't loaded with cd drives/hard drives should have these available so you shouldn't worry.
edit: oh an probably burning software like Nero (6.3 or above) if you don't have dvd burning software.
You're going to want 2 IDE cables, you don't want them both on the same cable. And as for media, TY(Fuji) are the best, the Ridata ones Newegg has for $30/100 burn very well up until 12x
Thats mainly only if the Fuji's are made in japan (which is written on the cake box). Aside from that, memorex's made in japan also tend to be TY's(taiyo yuden). Aside from that, people also are saying they're having better burns on Ricoh discs on the NEC 3500a.
