Here's a site that rates many of the programs mentioned here (note that at the top of the page the guy says what he uses...Proximitron and Antipopup):
Popup Killer Review
Popup Killer Review
Originally posted by: Gravity
I use the build in host file for ie 6. Here's a linky http://www.smartin-designs.com/
I see about 2 per day now that I'm using that. Now I just need a tool to take those flyers out of magazines!
Gravity
Thanks for the link, its an interesting site. They have tests for the different types of popups on the top of the screen. Although I don't understand why the guy who wrote that web page, uses Proxomitron and another popup stopper. Proxomitron stops all popups by itself. It even passes all the tests for me, that he has it labeled as failing.Originally posted by: Scrith
Popup Killer Review
Originally posted by: yukichigai
Originally posted by: airduct
IE + Crazy Browser = no Popups
is ne1 able to stop netzero's popups? this is the only thing i can't stop w/ CB or popup stopper. thanks
With the exception of the popups that say "please support netzero by clicking on ads" (the annoying in-system ones) you can stop all nz popups by doing something really simple. Go to your internet options, to the security section. Select "Restricted Sites" and go to modify the security settings. In there, disable everything. EVERYTHING. Once that's done, hit okay and then go to sites. Add the following url: http://nztv.untd.com . This is where all the popups come from. Once that's done you won't get any more popups from NZ.
Gravity
So, you update your hosts file with an entry every time you get a pop-up window at a website? I can see where that's much easier than using Panicware's pop-up stopper. :Q
Originally posted by: cameronj
Ewg... so many to choose from...
I can vouch for Free Surfer MK II.... just search google for that phrase. Installed it about 2 months ago and so far the count is up to 1116 popups killed. Not 100%, but probably above 95% which is more than enough for my needs.
Originally posted by: FreakyGuy
Even though Proximitron is last on your list I can vouch for it above the others. I don't know what you mean by learning curve, took me only a couple minutes reading the docs... I like how it can freeze gif animations and block ads not coming from the website your accessing.
Originally posted by: amheck
3 weeks ago I would have voted for AnalogX's Pow program, but ever since then, I can't have it runing or it will kill any browser window I have open. Too bad, too, since I spent a year adding sites and pop-ups to my kill list. Hate to see that one go, but I can't figure out a way around it.
Thanks for the list about the other programs. I've been meaning to find another.
Aaron
Originally posted by: JuryDuty
Well, for the past several hours, I have tried about every popup blocker listed, seeing what I liked best and least.
All in all, my favorite is Crazy Browser. It adds SO MUCH to the browsing expericence--and it actually uses IE as its base, so I don't lose out on the security updates, etc.
Crazy Browser aside, the only stand-alone I thought was worthy was AdShield and Pow! I'd have probably ended up sticking with one of those two if I didn't go for Crazy Browser instead.
