Originally posted by: everman
if(cpu_temp < 50 )
{ temp = ok
else
temp = hot
if(cpu_temp < 50 )
{ temp = ok
else
temp = hot
Originally posted by: skinman2
Hello
Here are my temps currently (idle):
MB: 31 C
CPU: 37 C
Case: 34 C
I Have 1 case fan in the back of case that is removing the hot air out.
What can I do to lower the temps?
Thank You
Originally posted by: BlueWeasel
What's so bad about those temps? My non-O/C'ed 2000+ XP is currently idling at 47C with the retail HSF. My MB temp is 31C on a Epox 8RDA Nforce2 board.
Give us a little more info about your CPU and the heatsink+fan combo you are using.
Regarding the case fans, you might want to consider installing an intake fan at the lower front of your case. Also, installing another exhaust fan at the rear would most definately help...
