- Aug 27, 2001
- 6,770
- 1
- 81
At a recent lan party a friend of mine's pc kept rebooting after a few hours of CS:S and he wanted to know why. I looked at it and after installing coretemp I noticed his e6600 was idling around 45-50c which seemed rather high to me. I ran prime95 and he was in the mid 50's in 2 seconds and up in the mid to upper 60's in less than 2 min. I pulled the pc apart and here is the basic cooling specs:
-Unknown Antec case with 5 120mm fans including one on the side right above the CPU.
-Basic Intel HSF with copper core.
-No filters so there was some dust buildup but not bad, mainly just on the trailing edge of fan blades.
I pulled off the Intel HSF and the thermal paste seemed pretty bad. I cleaned it all off, applied a very thin layer of AS 3 (another friend is borrowing my AS 5 right now) and remounted the HSF. His idle temps are now in the upper 30's but he is still getting to the mid 60's in less than 2 min with prime 95. I know there is a burn in time for AS but I was hoping this would cut it.
In the end I underclocked his CPU so he could continue playing for the night but that is just a temporary measure. What could be causing such high temps and how could I help? A new HSF is certainly not out of the question but those older model stock intel HSF's are not bad coolers. I'm using one on a E5200 (different core, I know) and have it overclocked to 3.4 with no problems at all and previously used it with an overclocked e6550, again, no issues.
Is there something else I'm missing that could be causing the problems? Oh, and as a FYI both speedfan and the BIOS pegged the intel HSF at 2300 rpm and nothing I could do would make that go faster, is that a normal speed for the stock cooler?
thanks!
thanks!
