Hot - DI-604 Cable DSL Firewall Router for $19.99+Tx
Yo2
1,456
This week at BB B&M it's on sale for $29.99-$10 MIR.
If you do not have a firewall get this one - it's very easy to set up.
Yo
Title edited by AnandTech Moderator
DTBH
652
well.... since i just posted on the other thread.... I just gotta post on this as well.
HOTT DEAAALLLLL!!! But can't buy it. Pls just slapped the big L on my forehead.
iwearnosox
16,018
This is actually a government plot to weed out suspected Al-Qaeda anandtech members. Readers interested in hot goat a$$ are clearly extremists, and will have their wherabouts summarily traced.
Yo2
1,456
Yep they sold out quickly...:(
dajeepster
1,974
16
Hotter than a goat's a$$
Please don't go into details on how you would know something like that:D
gggonzalez
35
This is a great little router, but you really need to update the firmware to version 2.0
DI-604 version 2.0
It will fix a download speed problem. Let me put it this way, before I upgraded, by downloads topped out around 500k bits per second, after the firmware upgrade, I have gotten speeds up to 3500 Kpbs! (Cable modem in a new neighborhood... yum!)
Kookolobongo
36
I was lucky enough to get an open box one of these (since they jacked the price up it'll be $25 after the rebate) and I had to call tech support for help, simply because the manual does not have the proper instructions to reset it back to default specs. So for anyone else having problems w/reset, hold the button down for THIRTY seconds, NOT FIVE like they tell you in the manual/online. Since then it's been a snap to set up.
pookguy88
1,426
how do u upgrade the firmware??
and what's with the instructions saying that u point to a certain IP using IE at first??
wtf? don't i install the cd first?
Kookolobongo
36
Shouldn't need to install anything from the cd. Hook it up, type in the IP listed, and it'll bring up the router configuration screen(s) using a web interface through your own browser. To install the firware, log in as admin, click the tools tab, clik the firmware button, click browse, and locate the bin file you downloaded and unzipped. Router will update itself and reboot (took mine about 3 minutes to do this) and yer done!
