- May 13, 2002
- 3,877
- 0
- 0
This can go into the hotdeals forum but it would probably benefit us more.
went to HarborFreight today to pick up some hole saws. got a set of 2.5 in - 5 in hole saw for $3. yes I said $3. the quality isn't all that great, but heck, it's 3 bucks. also got 2 packs of diamond cut off wheels. set of 5, I've been using these, they are much better than your standard or even reenforced wheels. they were $2.50. what else? diamond coated grinding set, about $3 also, so yea, if you have a Harbor Freight neat you, go check them out.
