This is just a FYI. There are ton's of hot deals out there, but this one sparked my interest.
Here's a pretty decent deal on upgrading older PC's where you don't want to buy new memory.
Shuttle AV18E, $56 shipped @ newegg.
Celeron 1.1A Retail, $52 shipped @ newegg.
Why do I think this was worthwhile to post?
-This combo should run fine with most non-1.26jiggawatt powersupplies
-You can use your existing PC133 or even PC100 ram
-The chip should be able to overclock to 1.46GHz out of the box (overclocker.com lists the average overclock at 1.527)
-Even when overclocked you can use PC100 because the VIA chipset can run memory at FSB-33MHz.
-The new "A" celeron's have 256k cache and are pretty decent cpu's for the buck
Not as high performance as a XP1600+ on the ECS board, but you don't have to buy DDR, powersupply, and heatsink.
Also, FSB selection is limited to 66,100,133 so if you chip doesn't make it your SOL, but it has adjustable Vcore to get them up there. Not bad for $108 shipped.
Now, everyone go buy two and run your favorite DC client on them!!!
Update :
1) motherboard is out of stock at newegg !?!?!?!?! I just checked !!?!?!?
2) Motherboard does not have integrated lan or video
Update :
