Hot!!! Antec Sonata case for $77.50 OTD
usernamemax20charact
2,863
While shopping at Staples today, I noticed that they were selling the Antec Sonata case for $77.50 out the door. It looks like they were clearancing these things out, so I guess that would make it a YMMV.
SKU: 505841
snowpeas
119
I believe newegg has it for around $70 also.
Edit
Well this is $90 Sonata
And this is $77Looks like sonata
I think the reason they getting it out is because ATX is getting dumped for a newer setup, forgot wat it called, btx? I was actually gonna build a new comp using the sonata case till i heard a new setup was being pushed by Intel so that the case dissapate heat better. Good deal if you can find it and want to build a comp now!
tedinde
328
BTX is just the cpu in the bottom front, it has been done before by intel. CPU is in the front bottom so the fans can blow over it. Bad thing is there goes you HD cages unless they are moved up to the back of the case.
And there is still going to be a giant need for ATX. They are not discontinueing or clearing out now for something that isnt out yet!!!
chewyboy
176
btx is not just "BTX is just the cpu in the bottom front" it's also the mb on the other side of the case, PCI express, another step towards legacy free mb's. it isn't just an atx mb with the cpu at the bottom. the only thing frum current cases (case/mb/psu) that will work with btx is if you have a full size box the current atx psu's will fit, but anything smaller will not fix.
anyway as for this price if your looking for this case that is a hot deal.
dirtrat
My Staples hasn't carried cases in a long time. Good luck in finding this, a HUGE YMMV!
dbuchthal
17
The $77 case at Newegg is the Antec 3700BQE. It's a pretty sweet case, in many ways nicer than the Sonata, but it doesn't have the glossy finish of the more expensive case. Check out this great review for more info on the 3700BQE, including comparison info on it and the Sonata.
2,863
Stores with quantity on hand
Store # -- Location = Qty
4 - portches = 2
6 - west spring = 2
8 - natick = 2
27 - spring va = 4
41 - columbus = 3
40 - hicksville = 1
51 - saugus = 3
75 - livingston = 5
88 - lancaster = 2
90 - torrance = 2
91 - west haven = 2
93 - cypress = 2
122 - covina = 2
126 - simi valley = 2
128 - wilshire = 3
138 - lancaster = 2
139 - pasadena = 3
164 - north long beach = 3
167 - danvers = 2
182 - garden grove = 4
191 - bradton = 3
204 - allenton = 2
210 - brandon = 2
217 - salem = 2
221 - pough = 3
236 - fall river = 2
friends checking for more....
These are qty's as of Sun. 2/15 11 a.m. pst
2,863
Update...
246 - leominst = 4
255 - saratoga = 2
270 - waldorf = 2
279 - elm - 2
288 - super = 2
292 - greenville = 3
296 - pitts = 2
322 - louisville =2
324 - elansing = 3
328 - holland = 2
329 - pottstow = 2
335 - mt. kisco = 3
352 - charles = 2
355 - erie = 2
364 - traverse = 2
366 - springfield = 2
EektheCat
280
called my local staples, and though they have 3 in stock, they claim it's not on clearance :( any way to PM themselves?
skeptic
62
Thanks, my local staples in CT had 2 on clearance. This will be the new case for my mythtv box :)
2,863
They are on clearance. Most employees don't even know what's going on half the time... managers included. They probably told you that because they wanted to buy them. That's why you should never mention the price, or ask them to check the price. Just have them check to see if it's in stock.
Mehdi
67
Thanks OP! The timing on this was perfect... I picked up the last 2 at the Beaverton, OR Staples store! :)
2,863
more stores with them in stock
Store # - location = qty
370 - taylor = 2
379 - battlecreek = 2
389 - greensburg = 2
401 - dubuque = 2
402 - yorktown = 2
403 - sawmill = 3
409 - vacaville = 2
414 - waterloo = 2
420 - pittsburg = 2
421 - port chatta = 3
433 - colonie = 2
448 - grosse point = 6
450 - franklin = 6
451 - lennxcol = 3
454 - bowie = 2
456 - beechmon = 2
479 - portage = 6
483 - valparai = 6
539 - carrollt = 3
575 - west man = 2
589 - saginaw = 3
590 - clairsville = 4
593 - sanramon = 2
594 - edgewater = 2
598 - austin = 2
599 - queens = 2
600 - new bern = 3
604 - clay, NY = 2
609 - beckley = 3
613 - grants = 2
616 - pasadena = 1
622 = 2
624 - portshu = 2
625 - vereo beach = 4
