Get the 2.5-inch External USB Notebook Hard Drive Case for $29.
CompuGeeks.
Easily back-up your notebook hard drive files!! This external 2.5 inch hard drive enclosure provides you with the option to install your 2.5-inch notebook hard drive into a high speed USB IDE external enclosure. This portable 2.5-inch enclosure features 512 Bytes unified data buffer allocated for return upstream and downstream data transfer rates up to 900KB/sec.
USB IDE 2.5-inch Notebook Hard Drive enclosure
USB revision 1.1 compliant
512Bytes unified data buffer
Allocated for return upstream and downstream data transfer : Up to 900KB/sec
Supports ATAPI-4 compatible 2.5" hard drives
Powered via the USB port
Includes USB IDE 2.5" HDD Enclosure, USB A-B cable, User's Manual,
Includes Driver (on floppy disk)
CompuGeeks.
