Kaido
Linkage MSRP $299
Manufacturer Product Page (product video at bottom)
User Guide (PDF) | Brochure (PDF) | Screen Material | Dimension Table | Vertical Limit Adjustment
I've had my eye on an electric projector screen for awhile (mostly for the "cool" factor of having it drop out of the ceiling automatically) but the cost of the screen plus the cost of shipping has been too far out of my target budget. Most places want $100+ to ship the screen to you and the screen itself is usually in the $300+ range. After doing some research I found the Elite 100" 16:9 Electric Projector screen for $155.12 plus shipping. Shipping worked out to $39.50 for ground, for a grand total of $194.62. That's right folks - an 8'+ electric projector screen for under $200 shipped! It has a few nice features:
-49" x 87.2" 16:9 widescreen (100" diagonal)
-Integrated IR receiver with basic remote control (add to your Logitech Harmony remote!)
-Built-in 12V trigger (syncs with your projector)
-Quiet motor
-Bubble-level included
-Ceiling or Wall mountable
-160-degree wide viewing angle with 1.1 gain
-Programmable adjustable vertical positioning
-Has the word "Elite" in it (hehe)
-10" top mask, 3" bottom mask
-MaxWhite screen material (easy to clean)
-65" x 90.2" screen size
-Black casing
-Ships fully assembled
-Standard 3-prong power plug, plug-and-play
-1-year warranty (might be 2 years, not 100% sure)
Here are a couple user reviews off Tiger Direct
I've just installed this screen - it was really a breeze! Shipment was quick, and arrived in perfect condition. The motor is quiet, although just a bit slow. I had planned on buying a unit twice as expensive, but saw this one and decided to give it a try. A tremendous value for the price, and a great viewing experince too!
I couldn't find any feedback on the internet for this screen so I went out on a limb and bought it anyways. Glad I did. The screen arrived with a slightly bent corner where it mounts to the wall. Though alarming, this was corrected easily with pliars. Installation only took about 30 minutes! (Got lucky w/ stud locations) You must supply your own mounting screws/anchors from any hardware store. First, and most importantly, the image looks WONDERFUL! I am using a Mitsubishi HD1000u projector, ceiling mounted w/ 13' throw distance. Looks 10x better than my previous screen: the wall. It retracts quietly and slowly. The remote is a little shotty, and must be pointed directly at the unit. You must push stop at your desired height. I cannot speak for the longevity of this product, or its motor, as I've only had it for 3 weeks now. But I will say this so far: Nothing else comes close in price vs. performance. Buy it. And FYI, I am a professional projectionist.
I'll be mounting mine around Thanksgiving break, so look for a review from me around then 🙂
-Quiet motor
-Black casing
