!Hot - 115 PIECE TITANIUM NITRIDE COATED M2 HIGH SPEED STEEL DRILL BIT SET $30.94 shipped!
Analog
12,755
COMES WITH A METAL INDEX
These titanium coated high speed steel bits run cooler and last longer than standard drill bits, they penetrate 75% faster, cut more freely so you use less power, and they don't expand with heat, so you get properly sized holes. Cool turning titanium bits are a must for metal workers. All bits can be resharpened.
Heavy duty metal drill index included.
01611-5VGA
How to order:
Goto you favorite coupon site for the free shipping & $5 off code.
Call harbor freight @ 1-800-423-2567
order away.
if you want to see what this item looks like, click here (note the wrong price): link
115 pc TiN drill set: $29.99
Handling fee: $5.95
Coupon -$5.00
shipping=free
Total: $30.94
wumpuskiller
188
Looks like an awesome set of drill bits (especially for the price). Many thanks for a great deal.
wumpus....
Analog
12,755
I've been waiting for the price of this to drop for some time. Last time I got this for $29.99 was thru the inside track membership, so this is pretty good with need for membership in that part of HFT.
huesmann
8,618
Are these the typical HF cheap Chinese-made stuff? How thick is the coating--thick enough to last more than a dozen holes?
TheDon
320
I've got this set. These are not industrial bits, (I have those too), but this set is worth twice this price.
arcas
2,155
TheDon: how resilient are they? Will they remain sharp after a couple dozen holes?
Analog
12,755
Originally posted by: blahblah99
Anybody know how reliable these bits are?
these are pretty good for the price. I've had a set for about a year and I haven't had any problems. The coating seems to have lasted and I've drilled dozens of holes in mild steel using many of the same bits. HTH
Analog
12,755
i noticed a coupon code out there for free shipping, $5 off AND a free attache case! The deal gets even sweeter!!!!!
