- Sep 9, 2004
- 192
- 5
- 81
So I have a device with a USB connection that I want to make available on my wireless network. This device is very far away from my router and/or PC and cannot be moved (it's an aquarium controller). I have been told that I could use a USB over IP hosting device, which usually converts to an ethernet connection. And since I don't have an ethernet connection anywhere in the room, I'd then need to use an ethernet/WiFi gaming adapter to make it available on my wireless network.
My question is on the USB over IP hosting device. Some of them are extremely expensive ($300+) and some seem extremely inexpensive ($20). I see simple USB printer servers for 20 bucks and under often. Here's an example:
http://www.ebay.com/itm/New-USB-2-0...783?pt=LH_DefaultDomain_2&hash=item3aab5ad0bf
All of these that I find generally talk about how they can support multiple printer protocols blah blah blah. But some specifically say that they will only allow the print portion of a multi function printer to work, not the scanner for example. Well this scares me. Obviously this part is specifically made for printers. BUT then I see an extremely similar one on Monoprice:
http://www.monoprice.com/Product/?p...rtby=&period=&rating=&seq=1&format=4#feedback
And it clearly says it can host USB flash drives, webcams, multifunction printers, etc etc etc. What makes these any different from each other? And are either of these going to work for what I need?
To cap this off, I've seen a couple of devices that seem to go directly from USB to WiFi, which would save me the money/hassle of the ethernet/WiFi gaming adapter.
http://www.ebay.com/itm/Edimax-high...306?pt=LH_DefaultDomain_0&hash=item1ea1a166f2
or
http://www.ebay.com/itm/TRENDnet-TE...717?pt=LH_DefaultDomain_0&hash=item462321aecd
or
