- Jul 10, 2006
- 6,551
- 0
- 0
Originally posted by: Pancake106
arent b3 chips supposed to have a tj max of 85c?? i was under the impression coretemp 96.1 changed all tj maxes back to 85c.
anybody have any insight on this?
Originally posted by: nyker96
I think stock 2.4 loaded 60 is bit high but acceptable, I am expecting less from Tuniq though. Maybe try reseating that thing. However, don't expect very low temp from even Tuniq on a B3 Q6600 that thing is a small inferno. Also check the RPM on your Tuniq fan. Make sure you using max.
Originally posted by: Apocalypse23
ummmm, sorry if i mean to bust your bubble but.....
http://images.anandtech.com/re...rclok-ion/interior.jpg
thats how you install the tuniq, lol, turn it sideways and check your thremal paste again, should be fine after you install it like in the above link.
For your case that is an OK install.
For cases where the PSU sits above the Tuniq you need the tuniq's exhaust to be fed into the intake of the rear exhaust fan, i.e. rotate the Tuniq in your photo by 90 degrees counter-clockwise.
This is not a bubble-burster unless you are assuming everyone owns your case. There is no one way to install a Tuniq, case geometry and PSU configuration dictates best airflow positioning of the Tuniq.
So with the way my tuniq is installed, I'm going with the airflow and not causing any disruptions right?
In other words, for my case and setup, my tuniq is installed correctly?
Your case gives you the option of having it aligned either blowing straight-up or straight-back.
http://www.newegg.com/Product/...al+Black+Computer+Case
Just don't have it accidentally blowing down towards your vid card. That would be counter-productive for overall case airflow.
Originally posted by: kmmatney
too late now, but I was going to ask if the Tuniq tower itself was very hot. If the Tuniq was real hot, then you probably had good contact on the cpu...
Just picked up a g0 chip for $200, will report back as soon as my motherboard is fixed.
Hey, what do you want for that B3 ????
Ok, just got the rig going ans installed windows, specs are
Q6600 B3 W/ Tuniq Tower + Tuniq TX2 Thermal Paste
Abit IP35-E
2X1 GB Corsair Xms 2 DDR667
XFX 7900GT
WD 160GB Sata II HDD
Samsung Sata DVD-RW
Antec NeoPower 500w Modular
Antec P182 Gunmetal
Here is a Screenshot of my rig running 4 instances of SP2004 (One on each core, SFF Test)
Those temps are pretty ridicoulius and i mounted the Tuniq tower exactly how the manual said, i also used about the size of a rice grain in thermal paste.
What did i do wrong?
Abit IP35-E
XFX 7900GT
Samsung Sata DVD-RW
Antec P182 Gunmetal
well..
I personally think that case is a bit.. cramped.. unless you installed more fans.. The front intake is bad.. horrible circulation.. even with fannage there.. alot of blockage.. bad case choice in my opinion..
Not an enthusiast case.. very nice case.. very decent for stock stuff no oc but I would never have bought it.. sell that case and get an Antec 900.. Looked at your case today.. bought another antec 900 for moms new rig with your processor..
Also I personally dont overclock friends or families computers without a beefy psu like 650 or higher..
And um yeah.. errors are very.. um.. bad..
Abit IP35-E
XFX 7900GT
Samsung Sata DVD-RW
Antec P182 Gunmetal
well..
But other people have the same case and don't have temps that high. Is it really the case causing temps to be more than 10C above what most others are reporting even with lesser heatsinks? Shouldn't the rear and top fan be moving at least enough air to evacuate the heat being dissipated by his heatsink?
Abit IP35-E
XFX 7900GT
Samsung Sata DVD-RW
Antec P182 Gunmetal
well..
True that.. imo yes and no.. Good intake fans with good breathing holes will make a world of difference.. He has a good suckout but the intake dead area/blockage isnt so great.. still must be a bad install but he cant go wrong with a Antec 900..
Could have bought the trusty Zalman CNPS 9700 .. It may be heavy but this things a chiller.. Anybody that isnt happy with a Zalman CNPS 9700 .. Needs thier head examined..
I am going to be lapping my tuniq tower this weekend.
