hoping my power supply will be ok when i get my new asus sabretooth 990fx card
eastyy123
49
i have a power supply model atrix 500t 650w will it be ok for the sabretooth 990fx card ?
have a 460 graphics card card phenom II 2 internal hardrives sata and 1 ssd drive
has these specs on the supply
Input 95 – 250VAC
+3V3 = 30A
+5V0 =30A
+12V0(1) =14a
+12V0(2) =15a
-5V0 = 0.5A
-12V0 =0.8A
+5VSB = 2.5a
ATX 24 Pin & 20 Pin Compatible
EPS/ATX12V 8 & 4 Pin
Molex 4 Pin
PCI-E 6 Pin
SATA Power
Floppy Disk
cheers
650W
Kenmitch
8,505
2,250
Not what you want to hear but....Short answer = NO
The power supply is one of the most critical components in a rig. It's up to you if you wanna keep using it or not. I'd suggest replacing it if at all possible.
The said power supply was built with objectional quality. As it ages it only gets worse. How old is the power supply?
Here's a review I found which is dated 2008 and the reason I ask how old yours is.
http://www.overclockersclub.com/reviews/atrix_500t/
Looking at the comments in the review I wouldn't use a brand new one let alone one that is multiple years old.
