- Feb 26, 2006
- 64,039
- 12,367
- 136
damn boomer you trained your wife to do laundry at 3am??? tell us your secret.
Proper training...The rest is a protected trade secret that I can't divulge.
Unionized labor?Proper training...The rest is a protected trade secret that I can't divulge.
No, because then you can take the battery out, go take a piss and flush the toilet and go back to bed.That is worse than the tendency for smoke alarm batteries to always start sending their low battery warning at 3:00 am, as mine do.
To the OP:
I would imagine with the sheer volume of bullshit you generate, ... this kind of blockage doesn't happen once a week.![]()
I learned this morning that if you have the sink filled with water (soaking a ham) and flush the toilet at ~1am you get to clean the entire contents of the toilet off the bathroom floor.
The dwarf has improper venting if a filled sink caused that. I have some bad plumbing to fix here due to poor venting.
No doubt. Maybe the dwarf has a troll living in his vents...
I don't think Orangeburg was use that often after the late 1920s, except for perimeter drain and it was use till the mid 1970s.That's common. He's in CA so "Orangeburg syndrome" likely does not apply. If the pipe has a belly (sag) it could be trapping waste and backing up. When this happens a snake job fixes it briefly as it will slowly clog again and the process repeats. If the run isn't near any hazards (like natural gas lines!) he could rent a backhoe and dig it himself. I'm sure he's more than qualified to do that.![]()
You only have 1 building clean out, the other 2 are perimeter drain clean outs.Lots of lulz in here...
I got up this morning and everything has drained...for now.
I have a 25 foot sewer auger that I'm going to try first...if that doesn't get it, (and I don't think it will) the neighbor has a 50 foot powered auger that we're going to try.
Fortunately, I have 3 clean-outs on the house to work with, so MAYBE I can get this myself.
NO septic tank. (thank gawd...I hate digging those up)
This makes my plumbing issue this week seem relatively minor. The wife tried to shove a huge mass of vegetable peels down the disposal. Immediately after I heard her say "Honey, the sink isn't draining. I don't know what's wrong!"
:biggrin:
Fuck you...gawd-damned commie pinko...
How's that TV coming?
Well, I was right the first time. The clog was after the washing machine. I had to snake the front clean-out then used a "drain king" to clear it...but for now, it's working <crosses fingers>
It COULD be caused by tree roots...there is a tree in the front yard that has horrible root issues. All of them on the street have the same problem. Surface roots, roots that go to the water supply from the street, etc.
We're prohibited from cutting the roots or cutting the trees down. Technically they belong to the city. Part of their "street trees program."
Why would having a full sink cause the toilet to overflow?
Sounds like I'm not the only one with drainage issues.
Then I hope that the city will fix it if it is indeed a root issue, otherwise, I would be doing it myself.
