Honda's new luxury jet with weird engine placement
Gibsons
12,530
35
Having the engines up high is usually associated with seaplanes and floatplanes to put them as far as possible from the water. Also on rough field capable planes to keep them away from runway debris. Neither of which would apply in this case.
More interior room? Ok, if they say so....
Seems like it would make servicing the engines difficult.
Underwing might be an option, but they'd have to use longer struts for the undercarriage or mount the wings higher. Plus the debris issue. Look how low to the ground it is.
BUTCH1
20,433
1,769
Needs bigger engines.
The Wiki page on it listed it's cruise speed @483MPH, that's fairly fast plus it's fuel-efficient, what I'm wondering about is the tiny size of those landing wheels although I'm sure Honda knows what they are doing..
Gibsons
12,530
35
They look like they'd fit on a scooter.
Feb 6, 2007
16,432
The other thing this picture shows off is that the interior cabin is, at best, four feet high. Good thing they have all that significant additional space from moving the engines to the wing. That'll make crouching in the aisles seem much roomier.
ElFenix
102,353
8,444
you don't have to have the structure back there that you would if the engines were hanging out back there. so you get a private lavatory behind the seats. and then luggage behind that. honda says it has more cabin room inside than its competitors. :shrug:
looks like there's a small galley area in the front next to the stew's seat, immediately opposite the cabin door.
manimal
13,559
8
elite circles are small and a cheaper to run plane makes it easier to slush fund it
12,559
That's pretty cool, but yeah, does it have a bathroom? Other than the engines, that is probably one of the most important features of an airplane. :biggrin: It's not like a bus where you can ask to stop on the side of the road so you can go pee in the bush. Or worse, explosive diarrhea like in that story. :biggrin:
Kaido
Feb 14, 2004
48,653
5,419
When you hit 40,000 feet, does VTEC kick in? (yo)
Probably gets great fuel economy too...it is a Honda, after all ;)
rh71
52,844
1,049
Those chairs do not really look very big. Not much space for the legs. Uncomfortable with one leg against the cabinet/wall.
yup my first thought - you'd think the seats are one of the 1st things they'd design for.
T_Yamamoto
15,007
795
I think it also reduces the amount of noise/vibration felt by the passengers? Since the engine is not attached to the body directly?
_Rick_
3,937
69
I think the advantage is you can go with the wings attached to the underside of the place, which frees up space, but conventionally, in small planes, needs the engine nacelles to be placed on the fuselage, as otherwise they'd have too low and you'd need extra long landing gear.
But if you put it on the fuselage, you need to route fuel to the engines from the wings, which reduces room inside the fuselage. By putting the on the wing, without disturbing lift, they thus save that room, and can use the low-wing configuration, which is probably advantageous for aircraft performance, construction and economy.
And less than 5 ft cabin height?
Maybe they'll hire shorty to serve the drinks.
