Honda Accord 1991: "Maintenance required" light is orange, is that bad?
TNTrulez
Banned
Aug 3, 2001
2,804
I mean the car still runs fine and all but the indicator turned orange. Is that indicator milage dependent or is something wrong with my car's engine?
Vortex22
4,976
It does that every 3000-5000 miles (I forget) to remind you to change the oil.
Stick your key in the little slot next to the indictaor to reset it.
phreakah
2,883
yup, same with my civic
Encryptic
8,885
chin311
4,306
really? thats cool, mine's been on in my 96 corolla for about 6 months :p, stupid EGR crap or soemthing, but it runs the same as ever before, screw emmisions ;), usually the light comes on for enviromental shiet.
LordSnailz
4,821
Originally posted by: rbloedow
Originally posted by: Superwormy
Originally posted by: Vortex22 It does that every 3000-5000 miles (I forget) to remind you to change the oil. Stick your key in the little slot next to the indictaor to reset it.
really? anyone got a picture of where I'm suppose to stick the key? TIA!
Encryptic
8,885
I'd post a picture, but I'd get banned in a split second. You'll just have to figure out where to insert your "key" on your own. ;)
Seriously, there should be a small slot next to that little indicator that you can push the key into and reset it. It ought to be somewhere on your instrument panel. At least that's how it is on my 2000 Civic.
