Homeworld 2 problems - anyone else?
dud
7,635
73
I downloaded the demo and installed it no problem. Every time I ran it though, the framerates were less than 1 frame per second, basically unplayable. I checked the resourse manager in XP and HW2.exe is using between 98 and 100% of my CPU cycles! I see other people having similar problems and others having no problems at all. Has anyone else had similar problems and gotten it to work?
Jeff7
41,596
20
Yeah, I got a Homeworld 2 problem - the Walmart I work at STILL didn't get the thing in yet!!!
But anyway....what videocard are you using? System specs? It should work; maybe it's an old video driver.
Edit: I just checked my Homeworld 2 CPU usage on my system; it's also at 99% when I'm back in Windows at the Task Manager with the game still running. But it runs just fine here.
0roo0roo
64,795
84
hm yea, what are your specs, runs smooth here on a lousy 9000pro and 2.4ghz xp. 1024x768 max settings
