Homemade water gun
kevinthenerd
2,908
I want to build my own extremely high pressure homemade water gun. It might double as a pressure washer or a water cutter one day. PVC will be way too weak. Do you think galvanized pipe is a good choice for this application? Where can I find high-pressure valves? Will brass do the trick?
kevinthenerd
2,908
Originally posted by: acemcmac
why don't you just get it over with and buy a pressure washer
even with a gas motor, it's not powerful enough, and the nozzle is usually too large for use as a water cutter
kevinthenerd
2,908
Wow, a water cutter runs at 60000-80000 psi. I have a long way to go to get that kind of pressure.
Edit: At 200 micron diamater with mach 3, you're using only a half a gallon per minute.
Drakkon
8,401
ahhh spring...
that time of year when a young mans fancy turns from that of sitting by the fire....
to cutting down friends with highly pressurized water :confused:
BigJ
21,330
How skilled are you?
You do realize under that much pressure, if you fvck up on your design, you're going to be carted off in a body bag, right? Well at least what pieces they can find of you.
kevinthenerd
2,908
No doubt. It would blow up the building. If I fvck up a design as a professional engineer later, I'd rather it be my own life than the life of someone else.
kevinthenerd
2,908
It's amazing to think that, for safety and fatigue longevity, systems like that have to be designed to withstand more than 100000 psi. That's simply crazy to me.
drnickriviera
2,447
257
You're determined to die in a blaze of glory aren't you? PSU welder, Race car made from galvanized fence rail, now this.
jlbenedict
Banned
Jul 10, 2005
3,724
look into some of the materials used to construct "Potato Canons"
They are usually designed for high pressure in mind
kevinthenerd
2,908
Hell yeah. QFT.
For the record, I gave up on the welder and bought one. If and when I decide to build a race car chasis, I'm going with DOM tubing or maybe chrome-molly.
TheoPetro
Banned
Nov 30, 2004
3,499
are you looking at something you can hold? cuz galvanized pipe gets pretty damn heavy at higher diameters.
kevinthenerd
2,908
Originally posted by: mercanucaribe
Originally posted by: Crescent13
diamond ftw? It can withstand up to 14.5 million PSI.
It would probably crack if you make something that big out of diamond.
When I first learned about synthetic diamond production, the first thing that came to mind was making an engine block out of it. It has the highest thermal conductivity of any pure substance (ignoring what they're doing these days with two-phase flows), and it's strong.
The trouble comes when you have an unexpected load (like a back fire or something). A metal will simply yield, but it will more than likely hold. A brittle material is all or nothing. There's no warning if it's about to break.
Diamond is obviously too expensive and impossible to work with. I don't have a laser cutter (yet).
kevinthenerd
2,908
I held a 10' piece of 2" ($50 at Home Depot) when considering my last project's materials. I had a hard time holding it. (It was the thickest they offered in the size.)
kevinthenerd
2,908
Originally posted by: Drakkon
ahhh spring...
Well, if fire is on your mind, I could always fill it with gasoline or something, but I'd have to work up a bit more courage to pressurize gasoline in a homemade water gun.
Edit: Google the video of the homemade flame thrower that uses windshield washer concentrate, which I believe is methanol.
kevinthenerd
2,908
http://www.anvilfire.com/FAQs/hydraulic_piping.htm
I normally reccomend schedule 80 up to about 3000 psi, and then go to schedule 160. At 10,000 and above I suggest the move to a coned and threaded system. I have worked at pressures up to 30,000psi with the trheaded and coned system.
Edit:
If you assume a factor of safety of 6 to 1 for pipe, which is a hydraulic industry minimum standard, schedule 80 above 1/8" pipe size is not thick enough for 3000 psi. Most of the hydraulic work we are talking about is with 1/2" to 3/4' pipe size. Schedule 80 1/2" is 2300 psi for 6 to 1 and 3/4" schedule 80 is 1950 psi. Schedule 160 3/4" is 2780 psi for 6 to 1.
MaxDepth
8,757
43
Well, hell, son. If you got your mind on things like that then...
I need something like a combination BBQ wood smoker and pressure cooker. I want to smoke a 12 pound butt in under 3 hours.
:D
kevinthenerd
2,908
:D
I know a good welder who's a total artist of steel. He made himself a VERY nice looking smoker. I wonder if I can look him up. (He's my uncle's friend, and I haven't talked to him in a long time.)
