Homemade Airduct for Alpha PEP66t Heatsink.
fondoo
Homemade Airduct for Alpha PEP66t Heatsink with some art boards and ducttape.
the airduct is attached to the alpha pep66t heatsink fan and i've also attached
another 60mm fan on the end of the airduct. the airduct pumps hot air through the duct
and outside of the case. theres a 60mm blowhole on the case window (plexiglass).
tell me what you think.
airduct01
airduct02
airduct03
airduct04
airduct05
website:
ASUS P3V4X M/B
Bad Dude
8,464
Nice dude. I like how you tie those IDE cables to the tiny size. What kind of tape do you use to tie them up with? Does it drop the temp any?
fondoo
i cut the IDE cables in 4's and then ganged them up together neatly, and then taped them squarely with electric tape. by bounding them squarely, it gives them a neat square tube look. then, i tape each ends so it holds and then each 1" i tape it with electric tape.
it beats paying $17-$20 for rounded cables and floppy cables, you know?
