- May 21, 2006
- 119
- 0
- 76
Brief Summary
1) I am wiring up a place with Cat6 cables.
2) In total will have about 10 or so points.
3) The place is 3 stories tall.
4) Will be using high speed fibre broadband of a least 100mbps - 1000mbps, exact service TBD.
5) Will want to have comprehensive WIFI coverage.
Questions
1) Is there a difference between Cat6 or Cat6a or is Cat6a just an updated version of Cat6?
2) Would you recommend going for Cat7 instead or is it too overkill.
3) May I know if the equipments I would need would just be a) Router b) Network switch c) Wireless Access Point?
4) Is Network Patch Panel absolutely necessary for a simple home networking solution?
5) Would any Wireless Access Point provide comprehensive coverage for a room that is about 600sqft-700sqft or 55sqm-65sqm taking that it is a square room with just 4 walls and the AP will be in the centre of the room.
Questions
