Originally posted by: YOyoYOhowsDAjello
Go out and listen to some stuff for yourself to see what you like.
If only one person at a time is going to watch stuff down there, then you don't need a center and could get away with a phantom center. If you're going to have people away from the sweet spot, then a center channel that matches the front two speakers fairly well is the way to go.
The center is where ~70% of sound might come from a DVD, so getting a good one is important.
Using those current speakers as rears and then getting a 5.0 set for the front/center/surrounds would probably be a good way to go.
If you want to check out some room treatment stuff, here are some starter threads
http://www.soundandvisionmag.com/idealbb/view.asp?topicID=28194
http://www.soundandvisionmag.com/idealbb/view.asp?topicID=38945
