home theater system to pc
ihav2fart
15
currently i have my pc hooked up with my lcd and i bought a home theater audio system.
i was wondering if it is possible to hook up the home theater audio system to my pc. does anyone know? thank you
DATANK1436
20
Yes it is, they make adapters that take a line out cable and turn it into the red an white audio connection. You can get them alot of places, I got mine at a local radioshack.
palehorse
11,521
OK, first things first... Exactly which "home theater system" did you buy, and exactly what type of PC do you have? Video card? Motherboard? etc...
If you have it, for audio only, I'd suggest using an optical line out from the PC...
ihav2fart
15
i have a samsung ht-z310 home theater audio system i was wondering if it can connect to my pc i have a sound card but i dont know what cable is needed.
palehorse
11,521
what soundcard do you have? does your motherboard also have audio output? One or the other should have an optical output... if so, definitely use that.
Be careful though. If you have the video and audio going to two different destinations -- TV (1) and "Home Theater system" (2) -- they may not play in sync. You may need to figure out a way to fix an audio or video delay.
you should be OK though...
palehorse
11,521
uhh my sound card is this http://www.newegg.com/Product/...x?Item=N82E16829102002 and this my audo system http://www.newegg.com/Product/...x?Item=N82E16882676096 what cable should i buy to connect them together?
Are you absolutely sure you don't also have onboard sound as part of the motherboard?
If that card is all you have, I think you're going to have a really hard time getting any decent sound through your new home theater... Those outputs you have are meant to go directly to 7.1 PC speakers... which you don't have.
You may think about investing in another soundcard with optical output, like this one:
http://www.amazon.com/TURTLE-B...go-Sound/dp/B0009MFQ4Y
Go for that Turtle Beach card with the TOSLINK cable combo for $60.47... you have to realize, when you start hooking PC's up to real sound systems, the interfaces are not cheap. That $60.47 is the best deal I could find for you.
Good luck!
palehorse
11,521
what about this http://www.newegg.com/Product/...x?Item=N82E16829102024 ? i have this coming in soon is it possible with this sound card and what cables would i need for that set up ? thx btw, im clueless with these stuff
Yes, that nice card will certainly work, but...
1) Be sure that you have the required PCI Express 1X slot on your motherboard for the card to fit into.
2) Be sure to download the latest drivers from Creative's website for XP and Vista. ***DO NOT USE THE CD THAT COMES WITH THE CARD!!! Do the following instead:
-- Click HERE to get to the download page for the driver pack
-- Click "AGREE" at the bottom of the page
-- Save the file somewhere you can remember
-- run the downloaded file by double-clicking on it
-- follow the instructions and use common sense to answer the questions. If you get stuck, come back here and ask for help!
3) You also need to buy an optical TOSLINK cable, like the one 6 foot long cable seen HERE.
4) Connect the cable to the optical Line Out port on the card and to the optical Line In port on your Home Theater system.
5) Make sure Windows is configured to output digital audio over optical (in the Control Panel under Sound); and you'll need to configure whatever software you're using to output properly as well. (MP3 software should default to Stereo output, but DVD software will need to be set to DTS or Dolby Digital, etc).
Let us know how it works out. Good luck!
ihav2fart
15
alright thanks a lot man ill be sure to do that ill let you know how it works out when i get the cable and sound card in. thanks again
Mar 10, 2005
14,647
HT-Z310
Connectivity
HDMI-CEC Yes
Wireless-Ready Yes
Wireless Module included No
USB HOST Yes
Composite Inputs No
Component Inputs No
HDMI Inputs No
HDMI Out Yes
SCART Out No
Audio Inputs 2
Optical Inputs No
Coaxial Inputs No
Multi ch in No
Multi ch out No
Headphone Jack No
Mic Jack No
you can get 2 channel left and right out of your computer and into your stereo. a new sound card can't change that. if you're getting that soundblaster card, you can still enjoy it by using one of these.
by the way, the soundcard you linked to fits in a pci-express slot. do you have a pci-express slot? take a look at this. it's a comparison of 4 x-fi cards, 2 pci and 2 pci-express. the price range is $55 to $95. creative doesn't sell a pci card with optical connections. in my opinion, if you have a pci-express slot the best of the bunch is the one for $60.
palehorse
11,521
Originally posted by: The Boston Dangler
HT-Z310
Connectivity
HDMI-CEC Yes
Wireless-Ready Yes
USB HOST Yes
Composite Inputs No
Component Inputs No
HDMI Inputs No
HDMI Out Yes
SCART Out No
Audio Inputs 2
Optical Inputs No
Coaxial Inputs No
Multi ch in No
Multi ch out No
Headphone Jack No
Mic Jack No
Amazon, Newegg, MacMall, Circuit City, and others all show the HT-Z310 as having an "optical input." I wonder if Samsung got it wrong on their own site...
Without an optical Line In on the receiver, that changes everything... :(
mmnno
381
Multiple amazon user reviews say it has an optical input.
ihav2fart
15
ya my home theater receiving module has the digital audio port like that red one not the circle one though
palehorse
11,521
you're good to go with the card you said you have on the way. Just follow the instructions I posted and let us know how it goes...
