Home Theater Questions
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,204
45
Well, I was told it would work several years ago, I tried it and it did not work for me. What resolution were you able to send from your comptuer with a VGA to Component cable?
t3h l337 n3wb
2,698
I want to go 5.1, but my mom's being cheap. We're spending about $15k finishing our basement with full bath, and she won't even let me go above $500 for speakers -_-;
MustISO
12
If you're on a budget, get the front three or just the L/R for now and then get the others as you can afford them. Speakers will last a long time.
zephyrprime
7,512
By the way, if you can really get stuff at BB for only a little above cost, I think that's the way to go because retail markups are pretty high so the corresponding wholesale discount would be pretty high as well.
Just an example: the sony STR-DG800 was being sold for $280 at Amazon last week but is $400 at bestbuy. Amazon is probably selling for ~%20 above wholesale so you see the discount would be pretty big at BB if you could get wholesale prices.
t3h l337 n3wb
2,698
Oh yeah, I have one more question. Can you mount bookshelf speakers, or are those too heavy? I wouldn't want a bunch of wires running along my floor from my rears.
PurdueRy
13,837
4
Yes you can wall-mount bookshelf speakers. However, if they are rear-ported make sure you get a wall mount that keeps them far enough away from the wall.
t3h l337 n3wb
2,698
Hmm, could I possibly mount them on the ceiling? I'm probably going to have a corner couch that leaves some room between the edge and the right side for walking. If I mounted them on the opposite walls, would the different distances from the couch be problematic?
PurdueRy
13,837
4
Provided that one is not rediculously close...the receiver will take care of that
t3h l337 n3wb
2,698
My mom realized that it wouldn't make much sense to buy rear speakers later, since the contractor could do all the drilling and mounting at the same time as finishing the basement. So she decided to bump the budget up to $1000.
YOyoYOhowsDAjello
Aug 6, 2001
31,204
45
I think the Infinity Primus series would be a stronger choice for you than the original speakers.
They have some pretty good deals at Vanns.
example:
http://www.vanns.com/shop/servlet/bundle/542199665/1149885208581
EDIT: CC has some nice deals too (looks like some rebates end tonight though...)
Primus 250s are $149 - $50MIR = $99 each
C25 is $99
Primus 150s are $70 - $30MIR = $40 each
So, AR you're looking at a decent 5.0 system with towers up front for $380
Add in a $200-$300 receiver
and you've got $300-ish left over for a sub.
t3h l337 n3wb
2,698
Wow, that's a nice deal. I think I'll go for it. Free shipping is awesome too. Since I'll have some money left over, should I get a better receiver? Or will the Pioneer be good enough?
YOyoYOhowsDAjello
Aug 6, 2001
31,204
45
t3h l337 n3wb
2,698
What speaker mountes should I get? These speakers are pretty heavy. I'll need mounts that support up to 20 lbs. What about an A/V rack? What's a cheap rack I can use to hold a receiver, DVD player, VCR, Xbox, and my center?
