- Jul 26, 2002
- 11,757
- 0
- 71
I have a number of questions I was hoping I could get some insight into. I've been doing a ton of research and have a number of different options, I'm just having a hard time determining the most cost effective/best.
My setup consists of a home theater room with a BenQ W1070 projector and a 120" screen. I have an old pioneer receiver that still works perfect, but it only has optical inputs, no HDMI. The speakers paired with it work perfect as well. The Subwoofer's power cord was chewed at the end a number of years ago. I was planning on repairing that, although I don't know exactly how. The hookups are a PS4, Cable TV Box and currently using my laptop as a makeshift HTPC. The problem with the laptop is two fold. One, I don't like constantly plugging it in/unplugging it, as it is my main laptop. Two, since the receiver has no HDMI inputs, the audio comes directly out of the projector, which is.... not ideal. I currently don't have any universal remotes, but ideally want to get one to control the receiver, STB, pc/htpc, projector and my HDMI switch.
So a few options I have.
Build a new desktop HTPC, throw a soundcard in there with an optical out and be done with it. I could go for an i-5 to do some light gaming on there, but most gaming is done on PS4. I wouldn't want to spend more than a few hundred on the system and am not opposed to piecing it together with used parts.
Or, I could get an external soundcard for my laptop with an optical out, those only run about $40 and I've heard they work ell. The problem here is I don't have a dedicated HTPC.
Third option, go the HTPC route, but ditch the optical out soundcard and replace my receiver as well with a newer one that can transmit audio via HDMI. I've heard it is superior, but exactly how much better is it? I'm not an audiophile.
Lastly, does anyone know of a universal keyboard with trackpad that can be used as a universal remote as well? I've read about logitech harmony smart keyboard, but the reviews aren't great on that. I can't seem to find any other options.
Anything I'm missing/should be concerned about here? Any advice is appreciated.
