Home Theater Help
hennessy1
1,901
Hi I was wondering if anyone could help me locate a 1000w or above with dvd player home theater with a digital coaxial audio and an optical input.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,204
45
Wattage ratings are pretty much meaningless.
What budget are you looking for?
EDIT: Is this relating to your other question as well? A decent receiver will have multiple analog as well as digital inputs on it by the way.
YOyoYOhowsDAjello
Aug 6, 2001
31,204
45
Do you want it to be an all-in-one set, or would you consider putting it together from different components?
Requirements on size etc.?
There are some pretty good systems starting in the $400 range, but if you have the budget for it, you can get significantly better stuff, especially in the speakers department if you put a set together yourself.
Did you mention 1000watts since you want something really loud? What sized room is this going into?
Is this mainly music or movies/gaming?
hennessy1
1,901
All in one. no size requirements. Yes 1000w because I want it to be loud. Its for an entire floor. 3 open rooms. Games, music, movies.
hennessy1
1,901
yes but i am looking for at least the rear speakers to be wireless and also to include a dvd player. onkyo is that a good brand to get specificly this model HTS894
