Home Theater help
geno
25,074
4
I'm aiming to stay cheap (well, I wouldn't call it aiming, I really don't have a choice :p), but I have a chance of getting one of these receivers for almost the same price,
First, I can get this Onkyo TX-SR500 for $130
or I can get the Onkyo TX-DS575 fir $150
if anyone has any other suggestions for around these prices, please let me know. The SR500 seems more entry level, where the 575 seems like a slightly older, but better receiver. Has anyone heard either of these receivers in person?
Any help is appreciated - thanks guys! :)
biostud
20,250
7,382
Personally I'm very fond of NAD, but it might not be in your price range.
apac
6,212
I own an Onkyo TX-DS575X and it's a great receiver, albeit a little old. Bought it for $200 in the fs/t forums about 6 months ago.
However, yours is not the 'X' version, and I have heard about troubles with that. Go to www.audioreview.com and search for your model to see what I mean.
geno
25,074
4
Originally posted by: LordSnailz
What other components are you planning to hook up with either one of this guys?
I have 2 Cambridge Soundworks bookshelfs (from their old MovieWorks combo, I believe they'll handle 100W RMS) along with the center from that setup. I need to get some rears and a sub, but I'm worrying about the receiver first for now...
geno
25,074
4
hm, that's not encouraging :eek: I don't like the sound of those problems
apac
6,212
Yeah I was looking at the TX-DS575 reviews by mistake a couple days ago and noticed those.
Do you have your heart set on Onkyo? I bet you can find similarly speced HK and Denon's in that same price range.
geno
25,074
4
No, I just think Onkyo is a good entry level brand, if Denon and HK can be had for between 100-150 (used or otherwise) then I'd be open to suggestions
geno
25,074
4
Originally posted by: DaveSimmons
www.jandr.com has the Onkyo TX-SR502 refurb for $149, that's 2 model years newer than the 500.
That's what I'd get for a budget under $200.
link for the lazy
Wow, great price for a nice receiver... is refurb reliable enough do you think? And I'm only looking for a 5.1 setup, can I get that with a 6.1 receiver like the 502?
murphy55d
11,542
link for the lazy
Yes. You just set it to 5.1 instead of 6.1.
MySoS
490
link for the lazy
Referb from Onkyo is very reliable.
geno
25,074
4
Hm, shipping for it puts me over my budget though :eek:
I want to wait until I save some more money so I can get what I want, but I'm seeing some really good deals around... I just need to be patient :p
DaveSimmons
40,730
670
The Onkyo 502 is an Onkyo factory refurb, tested by Onkyo. It comes with a 1-year Onkyo warranty, so it's safer than buying used.
geno
25,074
4
Well, after reading all of the bad things about the 575, I think I'm going to have to pass on that one :) Are there any other brands/models someone would recommend for the same price?
nsafreak
7,093
God I'm not sure personally I'm a fan of H/K receivers and HarmanKardon sells refurbed models of theirs on ebay from H/K direct. But even the AVR-230 (the receiver I have and love) is over your price range. Frankly I would suggest saving up a little bit more and then spending around $250 because frankly I think $150 is way too low of a budget.
