CADsortaGUY
Facts:
Leasing home(half of large duplex)
Owner hired contractor to install 3 smaller vinyl replacement windows and one large replacement picture window.
contractor slapped windows in and bailed(after receiving payment)
contractor work sucked and cost the owner extra because the siding people had to brickmold the outer.
Owner is NOT going to call contractor back to finish the inside(like was quoted and paid for)
Offtopic but still facts:
I have redone some of the interior for the owner previously. Mold had destroyed drywall around kitchen window and behind cupboards. I redid entire kitchen walls(fixed cracks, wiring, and other issues).
Issue:
Since the contractor didn't finish this a couple months ago(and sucks anyway) and with winter coming - I will now be doing the finishing on the inside of the new windows. The owner will reimburse me for the materials needed.
The small windows only need sill extensions and trim and just a touch of drywall work(due to crappy contractor), but the big picture window looks to need some work- also due to crappy contractor work.
The drywall under the window is now too short for trim to cover the gap and hide old paint line mark. The drywall also at one point had been "repaired" due to what I assume was a large hole. The "repair" looks like ass. Also around the bottom corners of the windows the drywall and paint are peeling away which will take some work to sand, smooth, and repair. And the last thing is that this piece of drywall under the window is now loose, again due to crappy contractor putting the new window in.
So, the question for those with experience is:
Do I just replace the entire piece of drywall under the window with new? Or leave the old stuff and try to "fix" it?
If the answer is "fix" then how would you suggest I fill the gap between where the sill extension and old drywall? With a narrow piece of drywall? or just get bigger trim?😉 Oh, and do you want come help with the fix?😀
If the answer is - replace. Good - I will be able to replace the insulation under that window then too, as it may have been water damaged due to the old picture window rot.🙂
Also - the existing trim in the room is old and a dark stain as were the old windows. With the new white vinyl windows should I try to match up the trim stain with the old trim or just paint it? The sill extensions will follows whatever the trim decision is.
Make sense?
Pics:
Hole"repair"
Hole"repair"B
left peal
center peal
right peal
Seam crack
old trim
old trim 2
long view
full view
Cliff Notes: Fix or replace drywall? Look at picture links^^^
Cute dog pics for those who don't care about the topic🙂
Thor
Thor2
Thor3
Thor4
k1.jpg through k47.jpg are from my kitchen project(caution - not dial-up friendly)
TIA
CsG
Issue:
Make sense?
Pics:
Hole"repair"
Hole"repair"B
left peal
center peal
right peal
Seam crack
old trim
old trim 2
long view
full view
Thor
Thor2
Thor3
Thor4
TIA
CsG
