Home Powerline Homeplug networking add-on?
techwanabe
3,145
I wish to extend the network in my home so we can get good internet in the basement and other rooms away from our WiFi router. My boss recommended a power-line kit that plugs into the wall near our router and ties in with an Ethernet cable, sending the internet throughout our household wiring.
Great! The kits seem to all come with a single adapter for the room where you need good internet performance - plug it into the wall and cable into it and good to go, like in the basement.
Here is the trick however, I would like to get an extra adapter, maybe even a couple extras for one or two other rooms. Searching the internet it appears that the add-on raptors are next to impossible to find. Help! Where can I find an extra adapter which works with the AV 500 Home plug standard? Preferably the same brand?
MtnMan
9,365
8,705
There also powerline adapters that become a second wireless access point in the far end of the house, or in your case the basement, plus providing an Ethernet connection at the remote location.
Set to the same SSID as your existing wireless it becomes a ESS and wireless devices will connect to the strongest signal based on their current location.
