Home owners: preventative pipe maintenance?
blackangst1
22,902
2,359
I just passed the one year mark in my home, and I was thinking. Is there any kind of preventative maintenance I should be doing as far as plumping goes to keep my pipes clean? Obviously the goal is prevent clogs.
What say you?
wirednuts
7,121
4
dont pour grease down them of course. oil isnt as bad but it can mix with other stuff and make sludge too.
otherwise, no. theres really nothing you can do. theyre very resilient as they are.
oh, and if you have a garbage disposal, get rid of it. all they do is turn solid waste into sludge that can clog pipes. its better to just shove solids down the drain with water because every 10ft or so the pipes get bigger, so if it gets past the sink trap it will get past everything.
Rastus
4,704
I pour a cup of floor stripper down each drain each month. Disolves buildup, doesn't work for clogged drains. It's cheaper and the same stuff as the Drano maintenance stuff.
For the other pipes, have your wife clean them out. Rinse. Repeat.
feralkid
16,864
4,979
No.
Don't ever do this.
NutBucket
27,151
635
WTF kind of backwards ass advice is this? Do you know anything about plumbing
marvdmartian
5,444
27
Good idea! I plump my pipes back up every year. Keeps 'em nice and round!! :whiste:
The only concern you really should have, IMHO, is if you have trees running close to your sewer line, and usually then ONLY if you have an older clay tile sewer line. Since your house is only 11 years old, it's likely your sewer line is plastic, so you should be good to go.
I have heard that if you have low-flow toilets, they do tend to not flush the sewer line quite as well as the older toilets that use more water. However, unless your lines are split up (gray water, i.e.-sink drains, and black water, i.e.-toilets), your shower water should be sufficient to keep the lines flushed. If you're worried about it, do a couple extra clear water flushes, per toilet, per month. :cool:
blackangst1
22,902
2,359
lol nice catch.
Thanks for the advice. I think Im good to go.
SandEagle
16,809
13
what about using Rid-X as a septic treatment? does that stuff work or is it snake oil in a box?
Greenman
22,270
6,448
Wrong on every single point. The ground up stuff from a disposal mixes with water and flows quite well down the 1 1/2" pipe required for a kitchen sink.
Pipe size is determined by DFU's and code minimums. Sinks are 1 1/2", showers and washing machines are 2", toilets are 3". Those are all code minimums for individual units. Multiple units requires that you add up the total fixture units for everything on the line and use a pipe size rated at that amount.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
With a garbage disposal, there are a few foods not worth grinding up - they tend to "stick" inside the pipes easier, even after the trap, if there's a relatively level area on the way to the stack. I'd recommend not grinding potato peels. Maybe others haven't had trouble, but I had to tear apart pipes in the basement two or three times as a result. Currently, septic system, therefore no garbage disposal. Chickens, so no need for one anyway.
Leros
21,867
7
I put some rotten asparagus down my garbage disposal last week. What a terrible mistake. I had to disconnect all of the plumbing under my sink to remove several clogs.
alkemyst
83,769
19
Celery is one of the worst. I did this in college, thinking a disposal truly disposed all.
I felt bad so I paid for the remediation. They weren't going to charge me for it. I also gave my 2 neighbors downstream affected by this $20 which was a great night out in the UF area at the time.
Leros
21,867
7
My parents had a really nice garbage disposal. You could put anything down and it never clogged. They put bones, peach pits, etc down it. I made a lot of mistakes after moving out because I had come to expect that garbage disposals had no limits.
CoachB
204
I advise the following on a monthly basis for the kitchen sink:
Fill (to the top) the sink with HOT water, add one cup household bleach, pull the stopper.
The hot water loosens any built-up grease while the bleach cleans and sanitizes.
You can do this in bathroom sinks every so often to help flush out soap scum and hair, also.
edro
24,326
68
I have had a garbage disposal my entire life, on a septic tank. (at my parents' house and my house)
I have never had a problem or remember my parents having a clogged drain due to it.
We used it daily. You obviously scrape your plates in the garbage first, but any remnants are easily ground up, passed to the septic and eaten.
The bacteria and enzymes easily consume food waste.
You might have to pump your septic tank like 1% sooner than someone without a disposal... Instead of every 5 years, it might be every 4 years and 11 months...
Seriously... people looove to give advice based on hearsay.
alkemyst
83,769
19
You might have to pump your septic tank like 1% sooner than someone without a septic tank... Instead of every 5 years, it might be every 4 years and 11 months...
what would the upper class be pumping if they don't have a septic tank?
