Hi guys,
I know this may sound like an odd question, but is it possible to use Coax wire instead of Cat5e for home networking?
Basically, the cable in my home is set up like this: There is a box outside of house where the cable from the provider meets the cable going into my house. Currently, I have disconnected the provider's cable and have connected a cable from my outdoor antenna. From there, the cable goes into my basement. Depending on which room/jack I want the cable service to go to, I connect the wire coming from the outside to the appropriate coax jack. There are about 8 cables, and currently, it is connected to the wire that goes into the living room jack.
I was wondering if I could use the coax wires for networking, and if so, what kind of speeds I'd get. Would it be worth it?
I currently have DSL, so I do not have any cable service.
I know there were some old ISA cards which did support some sort of coax networking, but the speeds were probably 10mbps or less.
Thanks,
Jawadali
Thanks,
Jawadali
